02. AutoPIPE command: Copy
Issues dealing with AutoPIPE's Copy command:
Item #1: Copying / pasting multiple pipes connected to header does not create a TEE connection at all locations
Item #2: How to Copy / Paste Beams?
Item #3: How to use Copy down command in AutoPIPE?
Item #4: Why Are Segment Names Not Displayed and Segments Showing the Same Color in AutoPIPE?
Cut / Copy / Paste / Rotate / Move / Stretch Command
