"Options to Renumber" model option, edit settings in an AutoPIPE model
Product(s):AutoPIPE,
Version(s):ALL
Environment: N/A
Area: Settings
Problem:
What options are available to renumber an AutoPIPE model?
 The following AutoPIPE commands can be used to renumber all or part of a model.
1. Tools > Model Options> Edit>
a. Default point name format
b. Default point name offset
c. Replace all point names on renumber
2. Edit> Renumber>
a. Segments
b. All Points
3. Edit> Segment> Reorder
Please read the AutoPIPE online help to understand how to use these options in renumbering a model.
Note:
There is one drastic process to renumber and reorder segments automatically, but is only used as a last resort and comes with a WARNING
Warning, after performing the following procedure it is highly advisable to completely review the entire model and all program settings afterwards!!!.
A. Open the file to be renumbered in AutoPIPE.
B. With the model opened, select File> Save-as> AutoPIPE Batch (*.NTL), save the file to a new name
C. Open the new *.NTL create in AutoPIPE.
This process will write the entire model using the NTL cards and format, previous node numbers and segment names are not saved during this process. However, any setting could be changed to a default setting when the NTL file is reopened by the program. Hence the major emphases, on reviewing all model settings, piping components, etc.. when the model is reopened by AutoPIPE
Tools> Model Options> Edit settings
