| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | March. 2017 11.00.00.22 |
What options are available to insert / override a code calculated SIF in AutoPIPE?
See the following options available:
A. Tee components
At the bottom of the dialog, select the drop down for "Type of Tee" and select "OTHER"
Depending on the piping code selected one or more fields will automatically appear where the user can override the calculated SIF values.
B. Flange components
Change "Joint End Type" to "User Defined" and enter Joint SIF values as needed.
C. Valve components
D. Flexible Joint components
Note: for all other component (Run, Bend, Nozzle, Reducer, etc..) or connections use one of the other options below.
Select an input grid tab for a component (ex. Tee). Set Type = Other / User Define, enter values as needed in columns not grayed out, as shown below:
Using AutoPIPE CONNECT 11.xx and higher:
Insert Ribbon> Xtra Data Group>
Press Help button on the dialog to get detailed information about setting options available.
Using AutoPIPE CONNECT 10.xx and lower:
Insert > Xtra Data > Joint Type & User SIF
