| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Seismic Load case | ||
| Date Logged & Current Version | Dec 2014 09.06.01.10 | ||
What is the recommended Seismic support spacing?
MSS SP-127-2001 (Bracing for piping Systems Seismic - Wind - Dynamic) recommends a lateral seismic support every 40ft and longitudinal support every 80ft.
But just note this guideline tends to be conservative and over predict number and size of seismic supports.
