| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Report |
| Date Logged & Current Version | March. 2017 11.00.00.22 |
How to find the axial stress at a section to be correlated with axial force in the pipe steel at the same cross section in AutoPIPE's General Stress output report?
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> General Stress Calculations > Longitudinal Stress
Removing pressure from the combination will disable the pressure component mentioned in the note at the bottom of the page.
