| Product(s): | AutoPIPE Nozzle |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | March. 2017 09.11.08.31 |
AutoPIPE Nozzle license status = Expired on the Activation Status tab of LMT, why?
AutoPIPE Nozzle V8i 08.11.08.20 and higher no longer requires a separate license line item as seen in LMT image below.
Using AutoPIPE Nozzle is now a feature in owning an AutoPIPE Advance or Nuclear License. Therefore, in order to use AutoPIPE Nozzle V8i 08.11.08.20 and higher for free, LMT must have a line item for AutoPIPE Advance or Nuclear. Otherwise, AutoPIPE Nozzle 08.011.08.20 and higher will not run.
With regards to the AutoPIPE Nozzle Expire message on the Status tab of LMT, at one time the computer had an older version of AutoPIPE Nozzle that required a separate license of AutoPIPE Nozzle. Again, AutoPIPE Nozzle V8i 08.11.08.20 and higher can be used if an AutoPIPE Advanced or Nuclear license is on License Checkout tab of LMT. Therefore, ignore the AutoPIPE Nozzle Expired message.
License Management Tool (LMT) issues
