| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | License |
| Date Logged & Current Version | Feb. 2017 11.00.00.22 |
"The Server succeeded but doesn't have a license for this product" message appears on the Activation Status tab of LMT,
Why and How to avoid ?
The first question is what version AutoPIPE is trying to be licensed:
First, look at the License Checkout tab to see what license are available:
As seen above, only AutoPIPE Advanced is available on this license. Therefore only AutoPIPE Advanced can be Activated on the Activation Status tab. AutoPIPE and AutoPIPE Nuclear may have been activated at one time or another on this computer, however with the current license settings for the user these 2 AutoPIPE editions are no longer able available and their status will eventually change to Expired / Diabled.
In the scenario above, start AutoPIPE and select Application button, then
Only AutoPIPE Advanced can be selected. IF Standard or Nuclear were selected the program will display the Activation status dialog, and IF a program / edition not on the contract was activated, than an invoice will sent at the end of the month based on edition license overusage.
Again, users should use only licenses currently available in LMT and if a project requires a feature not available in the currently edition to go ahead an enable the license knowing that an invoice for the usage of that license will be sent out at the end of monthly cycle. Once work on the License product / edition is completed, manually change the license in the program back to a license on the current contract . (ex. AutoPIPE Advanced).
This feature is a great money savings benefit to those who do not need another full seat on a contract and will pay for usage as needed.
License Management Tool (LMT) issues
