| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Calculation | ||
| Date Logged & Current Version | Oct. 2015 09.06.02.06 | ||
AutoPIPE calculates a SNiP hoop allowable of 178.39 N/mm2 in the output report, but 0.0 N/mm2 in the results grid, why?
In result grid Hoop allowable is calculated only for "Plastic Strain" category.
The results grid only prints the hoop allowable during plastic strain hoop stress check. It will never print a value for hoop allowable for the default combination Max P.
SNIP Piping Code Calculation Issues in AutoPIPE
