| Version(s): | ALL | ||
| Area: | Dynamic Analysis | ||
What Analysis Step value should be used on the Time history tab of the Dynamic analysis dialog in AutoPIPE?
Suggest using default setting "Automatic", thus letting AutoPIPE to solve the correct time step value needed for the analysis.
Some times the following appears when running an analysis:
Warning
W801-58: Smallest timestep for W1C01N .TIH file =.001392998 <.003152382 .
Consider a smaller user defined(non-automatic) analysis timestep.
This may indicate that modal cut-off frequency is not adequate.
OK
See WIKI here for details on how to resolve this warning message.
Dynamic "Time History" Analysis
