| Version(s): | ALL | ||
| Area: | Dynamic Analysis | ||
For the Time History dynamic analysis, is there anyway to run more than 4 file names at a time? I have broken the analysis into segments and have more than 4.
We apologize for the inconvenience, however this is a limitation of this dialog that only 4 time history files can be run at one time. Add additional cases as needed for a separate analysis with 4 other files.
Please keep in mind that a time history path can span more that one segment:
Example: Walkthru.dat, time history from A00 to B04:
Or on a straight line with multiple segments:
A. Insert Fluid transient as shown below:
B. Press OK button to see Fluid transient routing highlighted on the model, shown below:
Dynamic "Time History" Analysis
