| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Results | ||
| Date Logged & Current Version | Sept. 2015 09.06.02.06 | ||
Does rotating the model after performing a Fluid transient analysis affect AutoPIPE's results?
Yes.
The fluid transient command automatically creates the *.THL files. These THL files has force direction in them and would need to be re-generated to update force direction. Otherwise it needs to be manually updated.
