| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | Jan. 2017 10.01.00.09 |
Does the program carry out 1) Modal superimposition method or 2) Step by step time integration method for Time History analysis?
On the Time History tab of the Dynamic Analysis dialog there is a column called Integration Method. This allows the user to choose what type of integration method to be used for the Time History Analysis load case (M1..M50).
Dynamic "Time History" Analysis
