AutoPIPE V8i 09.03.02.05 |
137118 |
ASME NB, NC and ND combined stress may be non-conservative for skewed pipe |
137113 |
Tee header SIF is incorrectly used for branch in Japanese JSME 2005 code |
137157 |
Reinforced tee B2r < 1.575 and C2r < 2.1 are incorrect for NC/ND 2003 and later |
136992 |
Stress ISO: Metric DXF borders corrupt the file during DXF export |
AutoPIPE V8i 09.03.01.07 |
137074 |
SAM as Reverse dynamic gives zero SAM stresses in NB rev.dyn summary |
137083 |
Pulled bend flexibility factor is conservatively set to 1.0 |
137084 |
Maximum DT1 and DT2 stress is not used for tee in pre-verification report |
137040 |
Abutting bend stress indices are too conservative for pipe thickness < 3/16" |
137069 |
B2 is used instead of B2' for girth BW with thickness change for Rev Dyn Summary |
137071 |
NC/ND 2004 tee stress for reverse dynamic stress summary is conservative |
137049 |
Flange report pressure rating class = ***** |
137051 |
Exported DXF file is corrupted |
137044 |
Cannot run time history if a previously used THL file is not in model folder |
AutoPIPE V8i 09.03.00.08 |
137006 |
Branch Type Tee SIFs and stress indices for JSME code are using NC 2004 values |
137008 |
Problem with entering OTHER tee for JSME code |
137009 |
Abutting elbow C2 index is using NB 1992 girth weld C2 formula for earlier years |
135993 |
Changing pipe material in the input grid does not update thermal expansion alpha |
137144 |
ASME NB 1980+1982 Addenda is mislabled as ASME 1980 |
137002 |
ASME NB/NC/ND OTHER tee stress indices maybe incorrect |
137003 |
Eqn.8 & 9 stress summary may be incorrect at plus side of tee for NC/ND 2004 |
135698 |
ASME NB Thermal Ratchet shows Delta-T1 range from last load set pair |
135306 |
Moment summation at the tee for ASME NB ignores moment sign for second leg |
135837 |
SAM Axial stress results are zero for ASME ND code 94 or later |
135838 |
Incorrect MSRS analysis results when flexible joint or nozzle elements used |
135841 |
ASME B31.3 App P option causes different results in multiple load sets |
135723 |
Negative force/disp/gross disc. or cut short may cause incorrect stresses |
135731 |
Tee data switched when rigid options are inserted on a branch |
135796 |
ASME NB Equation 9 Allowable may change based on last load set pair |
135799 |
Transition weld SIF uses thickness at plus side of the joint |
135812 |
Some pipe properties for plus point is used for minus point for ASME NB, NC&ND |
135343 |
Allowable Stress and Design Intensity is incorrect for few materials in ASME1986 |
135356 |
Reinforced tee B2b & B2r stress indices are set equal for NC/ND 2003-2004 code |
135637 |
Problem with tee run moment summation for unsigned SAM cases |
135638 |
Moment summation incorrectly applied to reverse dynamic loads for NC 1972-1980 |
135690 |
B2' = 1.5 is always used for Socket welds for NC/ND 2001 and later |
135691 |
C2 should not be set to 1.0 when t < 0.237 in. for NC/ND 2001 and later editions |
135693 |
ASME NB 1989 socket weld indices for Cx<=0.75tn are always used for later years |
Critical and High issues released in version
