409868 |
Class 1: Tee summation rotation incorrect for tee nodes with name 'A19' |
407206 |
ASME NB: Global moment values are used for time history load case for non-tee points when "Modal/timestep tee summ" option is enabled |
372995 |
ASME NB thermal transient analysis gross discontinuity stress may be incorrectly calculated at locations involving last TTA pipe |
357535 |
Program crashes when NTL or Dat file is opened |
354225 |
ASME NB - Tee Moment Summation: Nested user-combinations having different summation for the nested combinations are not being combined correctly |
353032 |
346312 |
Snip & ChinaGB: Allowable values at points using material specifications with more than one thickness range may be calculated incorrectly |
334683 |
Non-linear analysis is incorrectly flagging supports as lifting off |
331101 |
ASME NC/ND: C2r and C2b stress Indices may be incorrectly calculated for fillet welded and partial penetration welded branch connections |
Critical issues released in version
