02. Under the Missing Mass Combination drop down listing in an AutoPIPE model, only the SRSS and Abs
Product(s): AutoPIPE
Version(s): ALL;
Environment: N/A
Area: Analysis
Date Logged
& Current Version
Dec. 2016
10.01.00.09
Problem:
Under the Missing Mass Combination drop down listing in an AutoPIPE model, only the SRSS and Absolute SUM method appear as choices. Where is Modal?
As seen in the online help:
    1. The Modal method is only available when using the Uniform Support Response Spectrum (USRS) option. As shown in screenshot below:
    2. If Modal is selected while MSRS is disabled, and you then enable MSRS, the combination method will automatically change to SRSS. As shown in screenshot below:
Dynamic "Response Spectrum" Analysis
