| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Modeling |
| Date Logged & Current Version | Dec. 2016 10.01.00.09 |
How many nodes need to put at the pipeline's Wave / surface interface in order to simulate the hydrodynamic forces CD and CM values on an underwater / subsea piping when using AutoPIPE?
One approach duplicated the same number of node points per span equal to the number of mass points per span calculated by AutoPIPE.
Model Subsea (Underwater) Piping
