| Product(s): | AutoPIPE | ||
| Version(s): | All | ||
| Area: | Export | ||
| Date Logged & Current Version | Mar. 2015 09.06.01.10 | ||
Can we use hot clash even without using i-model composer?
What are the effect if i do not use i-model composer?
The current "Hot_Clash_tutorial.pdf" tutorial only shows procedure, also no information to use i-model composer. only screenshot with i-model composer.
If i will not use i-model composer, can i still have the same result only with bigger file size?
No, you do not have to use I-model composer in the hot clash detection procedure.
The benefit for using the extra step of creating an i-model is to essentially create a locked file that cannot be graphically updated. Like an Adobe PDF, an I-model file is locked and cannot be graphically altered, but notes can be added, measurements taken / verified, etc.. This makes it a great collaboration type file format. However, not necessary if you wish to skip this step in the Hot-Clash procedure.
Export AutoPIPE Model (DAT) to I-model file format
