| Product(s): | AutoPIPE | ||
| Version(s): | All | ||
| Area: | Reports | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 | ||
How to get stress results for gravity load-case only in AutoPIPE?
Stress results are only produced for code combinations. Depending on your piping code selected in the model, the answer to this question can be slightly different:
ASME B31.1 and B31.3 Codes:
Review the online help for these codes, "Stresses Due to Sustained Loads". The pressure term can be removed by changing the following Tools> Model Options> Results options:
i. "Include Axial, Pcase in Sustained", unchecked
ii. "Longitudinal Pressure", set to "N"
As a result of the above settings modification, only the gravity term should be calculated for GR+MaxP code combination. See the results in the "CODE COMPLIANCE" section of the output report.
Sustain stress is calculated by Eq. #9 for NB code, and Eq. #8 for both NC & ND codes. In all 3 codes, reviewing the equations, the pressure term is dependent upon the internal Design Pressure. To remove the pressure term from the calculation, set the Design Pressure for the entire model = 0.00.
See the results in the "PRE-VERIFICATION STRESS REPORT" section of the output report.
"Code Compliance" sub-report using Results> Output Report
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
