| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | Oct. 2016 10.01.00.09 |
Why are dimensions missing from AutoPIPE Stress Isometric?
Reasons for missing dimensions:
1. First make sure that you have AutoPIPE Advance or Nuclear License Enabled:
File> License Configuration:
2. All Stress Isometric "View Dimensions for" settings are all turned off.
Within AutoPIPE, model opened, and analyzed, select File> Save Stress Isometric> provide a file name and press OK. At this point the "AutoPIPE Isometric Manager Options" dialog will appear.
Press the "Settings" button in the lower left corner of the screen.
Another dialog will appear with 3 tabs along the top, Select the "Dimension/Text" tab.
See the bottom left corner there is a group of settings called "View Dimension for", ensure that all boxes are checked ON.
Press OK 2x to create a Stress Isometric that will now have dimensions.
Stress Isometric Troubleshooting: Dimension Issues
