01. How to map a PCF converted support from V-stop to Spring in AutoPIPE
Product(s):AutoPIPE
Version(s):ALL;
Environment: N/A
Area: import
Date Logged
& Current Version
Sept. 2016
10.01.00.09
Problem:
 After import the following PCF support:
Into an AutoPIPE model it looked like this:
However it should be imported as a sping support in AutoPIPE.
How to map a PCF converted support from V-stop to Spring in AutoPIPE?
Using any word editing software (Ultr Edit, Notepad ++, MS Word, etc.), open PCFIN.MAP
File location when using AutoPIPE Connect:
C:\Users\(username)\AppData\Roaming\Bentley\PCF Translator\pcfin.map)
First, save a copy of the original file for future reference.
Next, Scroll down 2 tables from the top of the file to locate the [SUPPORT-TYPE] section.
Make the changes as noted above.
Save the file:
File location when using AutoPIPE Connect::
Re-import the same PCF file again.
Mapping examples from PCF translator to AutoPIPE
