| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Load case |
| Date Logged & Current Version | Sept. 2016 10.01.00.09 |
Can Snow (SN) load-case be used in a User defined combination?
At this time AutoPIPE V10.01.00.05, snow load has some limitations that helps address this issue. Please see the following AutoPIPE help section:
Help > Contents> Search Tab> enter "Snow Analysis Overview" (include the quotes), press List Topics button, double click on the selected topic from the list provided to see more information.
At the bottom of "Snow Analysis Overview" help page, there are notes and a section on limitations.
A new enhancement, TFS-E139512, has been logged to address these limitation.
