| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | Sept. 2016 10.01.00.09 |
The following message appears when opening a model from ProjectWise:
"E512-109: An unsupported version of ProjectWise found. Please install ProjectWise V8i"
How to avoid this error?
When the command is give to Open / Log In to ProjectWise, AutoPIPE tries to find ProjectWise executables from the registry if it does not find the correct version the error above is displayed. Supported versions are.
XM: 08.09.xx.xx
V8i: 08.11.xx.xx
CONNECT: 10.00.xx.xx
See Requirements section of AutoPIPE's readme file for compatible versions of ProjectWise with specific version of AutoPIPE.
Installed version of ProjectWise that is listed in AutoPIPE readme file.
