| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Report |
| Date Logged & Current Version | Aug. 2016 10.01.00.09 |
When creating an complete output report it is truncated at some point in the report when using AutoPIPE, why?
ex. the bottom of the report should look like this:
Instead it looks like this:with ASCI characters.
Known Reason #1:
When using AutoPIPE V8i 09.06.01.11, creating a complete Model Input listing report while enabling (checked ON) both "Use version 6.1 report format", and "Load Summary" options and then creating a complete Output Results report with "Model listing" enabled (checked ON), will create a truncated report as shown above.
Avoidance: Select from one of the 3 options below
Option #1: Do not enable "Use version 6.1 report format"
Option #2: If "Use version 6.1 report format" is enabled in the Model Input listing report, do not enable "Model listing" in the Output report.
Option #3: This issue has been fixed in a newer version of the application, upgrade software to AutoPIPE CONNECT 10.01.00.08 or higher.
Typical Comments, Questions, and Answers about AutoPIPE's Ouput Reports
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article into
a Bentley SR for review and reply. THANK YOU!
