| Product(s): | AutoPIPE |
| Version(s): | 2004, XM, V8i, CONNECT; |
| Environment: | N/A |
| Area: | Import |
| Date Logged & Current Version | Aug. 2016 10.01.00.09 |
Beams appear to be rotated after PipeLINK file is imported into AutoPIPE model, why?
STAAD rendered view:
File was opened in AutoPIPE:
Individual beams can be rotated as needed in AutoPIPE by modifying the Beam's Beta angle:
If all the beams need to be rotated about a central axis, select the affected beams and use Edit> Rotate command.
Note: This procedure does not include the rotation of the beta angle. See the limitation section for a complete listing of features that are not rotated by AutoPIPE.
A new enhancement has been logged to address this issue (TFS-E538054).
Insert> Model From STAAD Using PipeLink
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article into
a Bentley SR for review and reply. THANK YOU!
