| Product(s): | AutoPIPE |
| Version(s): | 2004, XM, V8i, CONNECT; |
| Environment: | N/A |
| Area: | Import |
| Date Logged & Current Version | Aug. 2016 10.01.00.09 |
When I import a model from STAAD the results are rotated 90 deg, why?
Confirm that Both models are using the same axis orientation. Global Y-axis or Global Z-Axis is Vertically UP in both models before importing the STAAD model into AutoPIPE.
Insert> Model From STAAD Using PipeLink
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article into
a Bentley SR for review and reply. THANK YOU!
