| Product(s): | AutoPIPE |
| Version(s): | 2004, XM, V8i, CONNECT; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | Aug. 2016 10.01.00.09 |
In an example model with SA312 Gr TP304 piping material with specific design and operating temperature as 640 degrees F. The properties are properly shown as:
Sh = 16280 psi
Syhot = 18080 psi at 640 degrees
Sc = 20000 psi
Sycold = 30000 psi.
When looking at the output results for Stress summary Level C the allowable stress is calculated to 34188 psi (2.1 * Sh). Why?
According to ASME NC 2007, NC-3654.2(a), should be the min of:
2.25Sh (2.25 * 16280 = 36630 psi)
or
1.8 Sy (hot) (1.8 * 18080 = 32544 psi).
Therefore, the allowable should be 1.8Sy (at temperature) = 32544 psi.
why is the Allowable 34188?
AutoPIPE is working correctly.
First note the Stress Summary dialog settings:
a. Reversing Dynamic loads is checked ON.
b. Allowable case is set to Design
Let us review the code:
Note: above images are excerpts from ASME NC-2007
The allowable in Section NC 3655(b)(3) = 70 % (3 * Sh) = 2.1 Sh, OrAllowable = 2.1 Sh Allowable = 2.1 (Design Sh) Note: because the dialog Allowable Case for Sh = Design selected, the design Sh was used in this calculationAllowable = 2.1 (16280 psi)Allowable = 34188 psi Same as shown in output report, AutoPIPE is calculating the allowable correctly. Note: This information is detailed in the following AutoPIPE help section:Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> Level C Service Limits> NC - Level C - Including Reversing Dynamic LoadsASME BPV-III-1-NC, AutoPIPE Nuclear Piping Code FAQ
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article into
a Bentley SR for review and reply. THANK YOU!
