| Product(s): | AutoPIPE |
| Version(s): | 2004, XM, V8i, CONNECT; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | June. 2016 10.01.00.09 |
Why does SAM results appear to be always +ve (positive)?
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Analysis Considerations> Seismic Anchor Movement Analysis> The following procedure is used to obtain the SAM results.
The last step of this procedure clearly indicates why the results are always +ve (positive) for all SAM results.
In order to include a -ve (negative) SAM case for review, create a user combination and set the scale factor for SAM load case to -1.00, as shown below
"Sam" (Seismic Anchor Analysis) - AutoPIPE load case
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article into
a Bentley SR for review and reply. THANK YOU!
