| Product(s): | AutoPIPE | ||
| Version(s): | V8i, CONNECT; | ||
| Area: | Combinations | ||
| Subarea: | |||
| Date Logged & Current Version | June. 2016 10.01.00.09 | ||
The "User Allowable" grid displays the allowable stresses to be used in the pre-verification and stress summary reports (ASME NB, NC, and ND codes only). The user may leave the field set to "Automatic", which will have the program use the allowable stress specified in the current nuclear piping code edition, or a user-defined allowable stress can be entered.
Combination Load Cases (Tools> Combinations dialog)
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
