Rotating equipment analysis:
AutoPIPE will automatically take forces and moments from all selected loads and user combinations, and perform a rotating equipment analysis per selected rotating equipment code without having to manually enter loads from each operating condition.
Depending on the rotating equipment code chosen, AutoPIPE will then ask the user to input the anchor points for suction, discharge, and other external connections as well as shaft axis. The API 610 analysis will require additional input for location of connection on the pump itself (side, top, or end), orientation, Table 2 factor, and center point offsets.
Once this basic information has been entered, AutoPIPE will automatically take the loads from all selected operating loads and user load combinations, and perform the rotating equipment analysis for each of these loading conditions.
Comments, Questions, and Answers on AutoPIPE's Rotating Equipment Dialog and Report
