| Product(s): | AutoPIPE | ||
| Version(s): | V8i, CONNECT; | ||
| Area: | Rotating Equipment | ||
| Subarea: | |||
| Date Logged & Current Version | June. 2016 10.01.00.09 | ||
When modeling a flange at the same exact point as an anchor,
Does the rotating equipment equations take into consideration the total of the forces/moments + restraint (anchor) or just the value from the Forces & moments report?
Rotating Equipment nozzle loads are determined from the pipe and not the anchor/support. So, if the flange weight is a load that acts on the nozzle, and/or the user plans to run a Rotating Equipment analysis then the user is advised to model the single point flange a short distance away from the anchor.
The development team does not see this as a mistake in the program but a modeling issue that is corrected by correctly modeling the flange weight in the correct location. This should not be an issue after CAE-CR-941 (Add Two Point Flange) has been added to the program.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
