| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT; | ||
| Area: | Stress isometric | ||
| Subarea: | |||
| Date Logged & Current Version | Dec. 2015 10.00.00.10 | ||
Before creating a Stress Isometric mulitple Break Points are defined, as shown below:
However, when the model is closed and re-opened the break point locations have all disappeared:
Why?
This is a known issue when a user creates these break points and then closes the model using the X in the upper right corner of the application screen or the Close command, shown below:
The proper way of closing AutoPIPE:
1. Select the SAVE button on the tool bar or use File> Save command
2. Then use File> Close or File> Exit command.
Then when the model is re-opened the Break Points previously defined will still be defined.
OPIM Stress Isometric Troubleshooting Guide
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
