| Version(s): | 2004, XM, & V8i | ||
| Area: | Results | ||
| Subarea: | |||
How to check AutoPIPE results with regards to summation of Forces and moments about a tee piping component.
First, see the following file for details: Summation of forces about a tee in AutoPIPE
Also see the following example:
AutoPIPE Forces and Moments report displays the pipe internal forces and moments caused by the applied loads. To be able to recreate the loading scenario on the Tee, you would need to apply the forces and moments in the direction opposite to the internal forces and moments displayed in the output report.
Considering gravity load case only for the tee point E02:
Results Post Processing in AutoPIPE
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
