| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Import - Crash | ||
| Subarea: | |||
| Date Logged & Current Version | Jan. 2016 10.00.00.10 | ||
The following is displayed while trying to import a PXF file into AutoPIPE:
Bentley AutoPIPE Application has stopped working
"A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
How to fix the model to import without crashing the program ?
There could be multiple of reasons why this has occurred, see the following known reasons and solutions:
The PXF file contains TAP Connections.
See the following WIKI here
Bentley AutoPIPE Application has stopped working - "A problem caused the....
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
