| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | June 2015 09.06.02.06 | ||
The following is displayed:
Bentley AutoPIPE Application has stopped working
"A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Program crashed when pressing the "Renumbering" button on the toolbars.
There is no avoidance, there is a problem with the model. Sometimes the issue is related to bends. Somehow program skipped to delete bend mid points. This issue and others similar can only be fixed by the CAE development team. Please log a service request, attach the AutoPIPE *.APC file and the development team will try and fix it.
This is a known issue, but no known reason as to the root cause. It will be good if you could remember any operations performed on bend. Was the bend deleted or converted to run/tee point using “Modify > Convert To” commands?
Bentley AutoPIPE Application has stopped working - "A problem caused the....
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
