| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Modeling | ||
| Subarea: | |||
| Date Logged & Current Version | Nov. 2015 10.00.00.10 | ||
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Example Systems> Steam Relief (Time History) Example>
Note: AutoPIPE Steam Relief feature can only calculate steam relief based on B31.1 calculations which includes both momentum and pressure thrust terms.
Loads and Load Sets - AutoPIPE
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
