| Product(s): | PULS, | ||
| Version(s): | all | ||
| Area: | Program Crash | ||
| Subarea: | |||
The program freezes or stops working when trying to display any results plots:
Answer:
Confirm the RPM setting is not too fine of detail for the plotting function to handle.
Example: Found the current setting for plot step = 3, change setting, RPM step = 5. The plot should now be displayed.
Program stops functioning when viewing color plot of model while trying to display results for all the frequencies, program stops working
Answer:
Please request that your IT department create a Virtual Machine (VM) with the following:
1. Win 7 with the minimal amount of features
2. No virus protection
3. Person logged on has complete admin rights.
4. Copy model to a folder inside the VM
5. Copy the following files to the VM:
a. pls08090028en.exe or pls08090028en.zip
b. puls08090029.zip
c. International.zip
d. iegls02002001en.exe or higher
e. Have ready Server name and Site Activation Key to us in LMT.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
