| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Date Logged & Current Version |
Sept. 2015 09.06.02.06 |
How to find the weight of a component or selection set in AutoPIPE?
Currently there is no method of selecting a range of piping and get the weight directly. However, there is a method to report the entire weight and Center of Gravity location for all the piping visible on screen in a model. See the following:
Tools> Model Input Listing> Center of Gravity (CofG) report.
For the given Model the total weight is reported:
Hide or delete part of the model to get a report on specific piping:
Re-run the Center of Gravity report
A new enhancement has been logged: TFS-E134372: CAE-CR-7986 - Add option to display weight of highlighted selection
03-k: Model input Listing - Center of Gravity sub-report in AutoPIPE
