| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | Sept. 2015 09.06.02.06 | ||
How do I know SAM displacements are in phase or out of phase?
A SAM load case consists of imposed support displacements and defined using the impost Insert> SAM / MSRS Support Group command and then adding displacement information on the Imposed Disp. tab on the input grids.
The primary feature of a SAM analysis is the ability to group (or phase) individual imposed support displacements so that they act at the same time. For example, floors of buildings (or buildings) are said to be in phase if all points are grouped on each floor (or the entire building) move in the same direction at the same time during a seismic event.
Essentially, for each SAM case and respective support group, the user will specify a response spectra file on the Dynamic dialog. For all SAM cases and Support groups that use the exact same spectra file would inherently be considered in phase (grouped). When other spectra files are defined for different groups then they would be considered as out of phase (group).
Please refer to AutoPIPE help for more information on SAM analysis support groups and combination methods.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
