| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | Sept. 2015 09.06.02.06 | ||
What is the difference between AutoPIPE and ADL Pipe in SAM analysis?
In AutoPIPE Powered by ADLPIPE, the program uses Absolute Sum for combinations on SAM cases.
However, ADL Pipe, uses Algebraic Summation for SAM results
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
