| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | June 2015 09.06.02.06 | ||
AutoPIPE has a discrepancy in the numbering of ASME B31.1 2010 equations. The numbers of the equations are those from B31.1 2007. i.e. B31.1 = Equations are 7, 15, 16 and 17. AutoPIPE shows 3, 11, 12 and 13 (from 2007 Ed.). The output file does not meet the Code definitions.
Please see the following:
TFS-D139050 or CAE-TR-11046 - Incorrect equation numbers for ASME B31.1 2010 edition and onward
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
