| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | June 2015 09.06.02.06 | ||
The following is displayed:
Bentley AutoPIPE Application has stopped working
"A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Program crashed when pressing the "Generate Default description" button on the Load> Load Case Description dialog screen.
The problem was that default description of SAM cases exceeds the maximum limit of Load case description length. This issue has been logged under TFS-D103020: application closes abnormally on generating default description.
Do not use the "Generate Default description" button if this occurred. Manually update the description names as needed. This will be fixed in AutoPIPE 09.06.01.xx and higher.
Bentley AutoPIPE Application has stopped working - "A problem caused the....
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
