| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | June 2015 09.06.02.06 | ||
The following is displayed:
Bentley AutoPIPE Application has stopped working
"A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Program crashes on exporting buried pipe options to NTL because model contains invalid value(zero) for pointer to buried pipe options.
To avoid the issue,
OR
Then NTL will be exported successfully.
Bentley AutoPIPE Application has stopped working - "A problem caused the....
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
