| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | modeling | ||
| Subarea: | |||
| Date Logged & Current Version | May 2015 09.06.02.06 | ||
What typical gaps values should be used for guide supports in AutoPIPE?
Use a gap setting appropriate to the situation or analysis requirements (ex. 0" to infinity) . Another words, this setting is dependent upon the stress in the model, if possible enter 0.00" gap but the situation (combination being applied) may require a much larger gap setting to pass analysis (ex. 3.5" gap).
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
