| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | Mar. 2015 09.06.01.11 | ||
All hydrodynamic coefficients change significantly when a pipe comes close to, or lies on the seabed. Is this effect incorporated automatic in AutoPIPE's calculations?
Unfortunately at this time there is no proximity adjustments to the automatic Hydrodynamic data or calculations when piping nears the seabed floor.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
