| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | Mar. 2015 09.06.01.10 | ||
When using the "Convert Point to" command AutoPIPE will not allow it, why?
Correct.
Actually this is a common block for Xtra data, as it is not included in the "Convert Point To" routine. When Xtra data is accessed it updates the local variable that store the menu item key.
A new enhancement has been added, TFS-E87051: Point having extra data cannot be converted to other types.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
