| Version(s): | 2004, XM, & V8i | ||
| Area: | Modeling | ||
| Subarea: | |||
When I copying and pasting after Pipe 1,2 Modeling as below , Tee is not applied at Pipe 2. It is OK when I copying Pipe1 and Pipe2 separately but it is very uncomfortable if there are many number. Would you explain if there is any
When copying multiple pipes as shown in Fig #1 above, select the node point location where the pipe is to be pasted too, and start the Paste command. When the Paste dialog screen appears, press the "HELP" button for detailed understanding about PASTING.
There are rules and will yield significantly different results:
If no range has been selected:
If a range of points has been selected:
In addition, see Help> Tutorial> First Tutorials> Creating a model> Copy and Paste for a video demonstrating copy / paste command
