| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Subarea: | |||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 | ||
For ASME ND-2007, Why is Eq. 11 missing from the AutoPIPE's "PRE-VERIFICATION STRESS REPORT"
That is correct, Equation 11. is calculated based on the results from Eq, 8 and Eq 10a. Therefore the results of Stress, Allowable and Stress Ratio are printed in the Stress Summary sub-report only.
In addition, note that Eq. 11 is calculated based on the code calculation, please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> ASME B&PV-III-1-ND> Level A & B Service Limits> NC - Sustained Loads & Thermal Expansion Requirement (Equation 11).
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
