| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 | ||
Can user control which columns to print in the "Result Grid" mode? All I am interested to see in the print out is the first eleven columns (SEG to GlobalFR inclusive). Can it be done?
Yes and No.
On the Results grid, the Print button feature will print the entire grid. There is no user control over the columns that are printed.
Recommend the following procedure:
1. Open the Results grids.
2. Select the top left cell in the grid to select the entire table:
3. Press Cntl+C to copy highlighted information to the clipboard
4. Open MS Excel, start a new file, place cursor in cell A1, and press Cntl+V to paste contents from clip board
5. Modify the cell height / length as needed, and print using the powerful functions of MS Excel
Furthermore, instead of selecting the top left cell, select only those columns from the input/results grids to be copy pasted to MS Excel and ultimately printed.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
