| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | Jan 2015 09.06.01.10 | ||
In a nuclear power plant, the containment building is filled with water, how to apply Response Spectra Earthquake and its affects of water in the building to the piping model in AutoPIPE?
Suggestion is to correctly apply the following 3 items to the piping model:
A. Insert> Xtra Data> Hydrodynamic Data
B. Load Buoyancy
C. Load Response Spectra
It will be important to include added mass coefficient (Ca). This will impact the calculated frequencies for modal analysis, which in turn will be used in the Response Spectrum analysis.
The user will have to come up with an approximation of what type of hydrodynamic loading (waves) may be generated by the seismic activity. This again will then need to be incorporated in the model using the Wave loading. Buoyancy loading will need to be applied separately to calculate the lift forces.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
