| Product(s): | AutoPIPE ATS | ||
| Version(s): | 2004, XM, & V8i | ||
| Area: | Installation | ||
| Subarea: | |||
Version: Compatible with Bentley AutoPIPE V8i SELECTseries 4 Maintenance Release 1 (Version 09.05.01.02)
Build Type: SELECT Release Product
Operating Systems: Microsoft Windows (see System Requirements for specific details)
Language: English
Date: June 11, 2013
The Bentley AutoPIPE Acceptance Test Set (ATS) provides the user with a recommended procedure for validating the integrity of the installed AutoPIPE 09.05.01.02 program. Since software validation and verification is a common requirement of mandated quality control procedures the ATS is available to all AutoPIPE users as a benefit of the SELECT program.
Prior to any commercial or Quality Assured release, the accuracy of the AutoPIPE program is verified by the execution of Alpha Tests. These Alpha Tests consist of a matrix of test systems designed to capture key feature attributes related to numeric and functional processing. Each set of test outputs is compared to a prepared set of expected results (i.e. hand calculations, some other well-established computer program, etc.), and evaluated for acceptance. The test matrix has been developed, verified, and documented per the requirements of the Bentley Software Quality Assurance Procedures (D/N# QAP).
The Acceptance Test Set includes input files and full documentation covering a sampling of test systems and results documented from the Alpha Tests.
Although many program features are verified by the ATS, it should not be construed as being complete for testing of all program functions. Additional tests for specific program features are continually being developed.
This document contains information regarding:
You must have a CD drive or Internet access for product installation. The following prerequisites are required to run the Acceptance Test Set for Bentley AutoPIPE V8i.
AutoPIPE |
A fully authorized copy of AutoPIPE Version 09.05.01.02 must be installed on your system prior to installing the ATS system files. |
Processor |
Intel Pentium III or higher |
Operating System |
Microsoft Windows XP Professional SP3 or later OR Microsoft Windows Vista Business or higher Microsoft Windows 7 Professional or higher |
Memory |
Minimum 2GB |
Hard Disk |
The uncompressed input files (DAT, CMB, UNT, SPC, XML, and OUT) require at least 90 MB of hard disk space. |
Input Device |
Any industry-standard input device supported by Windows. |
Output Device |
Any industry-standard output device supported by Windows. |
PDF Reader |
Adobe® Acrobat Reader 7.0 or greater. |
MySELECT CD:
When you order a custom CD from MySELECT CD the product directory structure for this product appears as shown. To install from the CD locate and run the setup.exe file following the online instructions. Refer to the Installation Help below.
|_autopipetestset
|_09050102en
||_product
||_install
||_setup.exe - This initiates the installation process. Follow the instructions given below.
Download from SELECT Services Online
- the download process gives you a choice to save the file to a specified location, or to begin the installation from the download area. Follow the instructions given below.
Before you install the Acceptance Test Set files, you should confirm that you have adequate hardware and software capabilities to execute the test samples.
Licensing: There are no authorization or License File requirements to use the AutoPIPE Acceptance Test Set.
Full documentation, provided in pdf format is installed with the test files. You can also download the documentation from the documentation button.
Documentation is provided in PDF files and can be browsed, searched, or printed with the Adobe Acrobat Reader. Information regarding the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
If you do not have access to the World Wide Web, please contact us so we can provide you with the necessary files for using the Adobe Acrobat Reader.
The user document numbers which correspond to this release are:
DAA037360-1/0001 - "Tutorial"
The "Acceptance Test Set" document number which corresponds to this release is:
QA25API-9.5.1
Error reports are available with client participation in the "QA & Reporting" services. Please visit our Online Support login page at...
http://selectservices.bentley.com/en-US/
...in the Support Tools column near the bottom, select the 'AutoPIPE & STAAD.Pro Error Reports'. The requested User Name is your email address, and the Password is that which was previously assigned by your SELECTservices Site Administrator. Once you are successfully logged in, select the Link 'AutoPIPE & STAAD.Pro Published Errors'. This action will produce the 'AutoPIPE and STAAD Error Reports' page. Choosing the Error Reports tab will bring up a page that allows selection of the database for each major workgroup, and product Select 'Computer Aided Engineering', and the product you are interested in (the default is 'All Products'). Next, press the radio button for the 'Select a Time Frame" section. The two list boxes allow selection of the time period (month and year) and format style. Report type 'Simple' represents a summary set of information, where 'Complex' produces all publishable information related to the errors. The error reports can be printed directly as displayed, or they can be pasted into a word processor or spreadsheet program to allow custom formatting or permit word searching. Note that if the 'View Open Items' radio button is selected, a cumulative open error report will be generated.
© 2013 Bentley Systems, Inc. Legal Notice
U.S. Pat. Nos. 5,784,068 & 5,815,415 & 6,199,125
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
